I started on finishing up the elevators today by finishing the trim tabs. I managed to get one completely finished.
I thought I would be able to use the pneumatic squeezer, but ended up needing to use the hand squeezer because of the tight spaces. All of the rivets turned out well.
One side note, if you're just starting this step, draw a line down the middle of the hinge before you drill--it will help you line up the holes. mine are pretty good, but a couple of holes toward the end are just shy of where they really should be. The good news is that there is no issue with the range of motion.
