Bens RV-10 Site (Non-Active)
Date: 12-3-2011
Number of Hours: 1.50
Manual Reference: Ch 7
Brief Description: Rudder Final Assembly - Trim Tab
I began the rudder final assembly this morning. The one final piece of prep I had to do was to scotchbrite the trailing edge wedge. As I was doing that, I snapped it in two at its weakest point. UGH !@*&^&*^
The snap was about 2/3 of the way down the rudder. Oh well...I had a solution instantly in mind.
I had already fabricated a rudder trim tab that I was planning to add on to the end of the rudder towards the bottom. I had originally thought about just riviting the tab to the OUTSIDE of the rudder. Because of the snap, I decided to integrate it into the trailing edge.
Now...some discussion...
1. Why the trim tab? There's been a good bit of discussion on the boards about how the RV-10 suffers from a need for right rudder . Many builders have come up with a possible solution to this problem. I have seen some cut out a section of rudder and use an electric motor, others have used a piano hinge.
2. Why my solution of a ground-only adjustable tab? Well, after discussing the issue with my instructor at the SportAir workshop I did a few weeks ago, I thought the idea of a simple tab was the best solution. It's easy to install, easy to maintain, and takes care of MY needs. (I'm building a 4-seater "family" plane...not an acrobatic plane. All I care about is the rudder in cruise flight.
So...here we are at my solution.
BTW...I'm not worried about the gaps (see photo 1 below). Since the break occured at one of the stiffners, and the sealant/adhesive that's going to be spread, it should be plenty strong.
The tab is made of standard aluminum plate, and the striffner on top of the tab is just another spare.
