Brief Description: L F/Tank: Installed Cap. senders and inboard rib
I installed the capacitiance senders and test fitted everything. I cut the sender wire to length and soldered on the lugs. I then prosealed and rivetted the inboard rib in place with the pneumatic squeezer and filleted wwith proseal as required. I also encapsulated all fitments with proseal as per spec.
