Brief Description: Right Rudder Hinge Pin Stay Installed
Prepared the area and Filled it with FLOX with the Pin in place. I used clear box tape around the Pin to ensure the FLOX didn't bond to the pin. After the FOX cured I removed the PIN and Drilled a hole and used 5 min Epoxy to install the Pin Stay.
