Brief Description: Installed Click bond to mount Master switch Relay
Installed 2 click bond fasteners on the Left side of the Nose compartment. I sanded the Area and prepared it for bonding the Fasteners onto the inside left nose compartment. I drilled 2 holes in each Fastener base and wrapped the threads of each fastener with Teflon Tape. I then embedded each fastened into a bed of Flox and covered it with 1 ply of BID. I still need to repaint the area with Zilaton
