BEZJet Build
BEZJet
Strakes
6-3-2013
Cut out Right MLG Door
I placed the Strake in the correct position and then placed the wheel well over top and traced the cut out area. I then transfered that to the bottom of the strake and added 1/2" wider to make a 45 deg bevel. I then cut out the MLG door
Door Laied out and ready to Cut out
Door all cut out
Trial fitting the Wheel Well
BEZJet Home
1426
Aileron
Antenna
Brakes
Cockpit
Firewall
Flight Controls
Fuel Sump
Intake
MLG
Motor Mount
Nose
Nose Landing Gear
Speed Brake
Strakes
Winglet
