2011/10/01: Made a Template then transfered it onto the Foam sheet. Cut out the Items and Laminated Ribs for Thigh Support and Left Console with 1 ply BID and Vacuume bagged. After it cured I trimmed and removed the peel ply.
2011/10/09: Cut uot center section and covered it with plastic wrap. Taped it back into place and laid up 2 plys BID around the edge to create a Lip for Speed Nut attachment
2011/10/16: Installed Console side wall See Image #3. Preparied surface area and Glassed the Console side wall into place. Also Added 2 ply BID over screw holes to reinforce local area around finishing washers.
