BEZJet Build
BEZJet
MLG
11-8-2014
Main Landing Gear door
I cut the MLG Doors and installed the Carbon Hinges for the Grass cutter door. after installing the hinges I then removed 4 hinge lobes and installed 4 springs so the grass cutter door will spring open.
Hinge Installed
Hinge Installed
Grass Cutter Door fitting
BEZJet Home
1426
Aileron
Antenna
Brakes
Cockpit
Firewall
Flight Controls
Fuel Sump
Intake
MLG
Motor Mount
Nose
Nose Landing Gear
Speed Brake
Strakes
Winglet
