BEZJet Build
BEZJet
MLG
3-4-2012
Installed Strut Extension PSI sensor
Installed and extended wires for the Strut Pressure Sensor. Splices on wire extensions to the Hyd Guage (Red, WHite and Black). Soldered wires then heat shrank each individual wire then Heat Shrank over all splaces.*
Strut PSI Sensor installed
BEZJet Home
1426
Aileron
Antenna
Brakes
Cockpit
Firewall
Flight Controls
Fuel Sump
Intake
MLG
Motor Mount
Nose
Nose Landing Gear
Speed Brake
Strakes
Winglet
