Brief Description: Installed Hydraulic Lines from Switching Valve
Installed Hyd Tubes for UP, Down, and Strut Extention into Swtching Valve. Let enough tubing proturing around end of Spar to interface with Strake Bulkhead when I sinstall it later. Still Need one more fitting (A-400-3) to install the Up Pressure Switch.
Hyd Tubes Installed for Swtching Valve
Strut, Up and Down Tubes coming out of end of spar
