BEZJet Build
BEZJet
MLG
12-27-2011
Installed Grounding Black and Power Block
I installed a Power terminal and Grounding Block on the forward side of the nose petition. I then installed the Main Landing gear controller.
Terminal Blocks Installed
MLG Controller Mounted in Place
Hyd Lines Installed
BEZJet Home
1426
Aileron
Antenna
Brakes
Cockpit
Firewall
Flight Controls
Fuel Sump
Intake
MLG
Motor Mount
Nose
Nose Landing Gear
Speed Brake
Strakes
Winglet
