Brief Description: Finishing the Bottom of the plane
I used Super fill on the bottom and thought I got it thick enough to do just one fill and sand down to the contour. Well I didn't so I had to apply super fill two additional times around the speed brake to bring everything up and flush. I wanted to ensure a free air stream over the speed break so that I would get good flow into the NACA scoop. Sanding, Sanding and MORE SANDING. I went all the way down to 120 grit. Started with 36 grit to knock off the high spots and then up to 40 grit and then 80 Grit and finally 120 Grit... Probably over kill. Next step for the bottom will be to squeege Epoxie all over to fill in the pin holes
