Laid up and bagged the Top Right strake then Chased leaks for F(*&@(#*ing EVERY. Finally pulled 15" vacuum and called in good. After the strake cured I removed the strake from the mold and fitted it to the fuselage and trimmed to get a good fit. I will need to use a router to route out the area above the wheel well to get it to lay down.
