Borrowed Rich Martin's top strake to do a trial fitting prior to attaching the bottom strake. I wanted to verify the leading edge is close and matches up. I discovered a couple of things. The Wheel well bucket is sitting to high to allow for a flush fit of the top strake. I will either have to remove the top of the wheel well or carve out the area of the strake above the wheel well or both. the other thing I found was the straps on the end of the strake are very close to the area I need to cut out and create a ferring to remove the landing gear. I think I can work around it but it is close. I also determined where I need to locate the fuel cap.
