Sanded and Fitted the MLG door and tub preparing it for Layup and closeout. I will close out the door with 2 ply BID and once it is cured I will use Micro to get a nice 45 degree angle on the door. Once that is cured I will FLOX all the way around the MLG tub seam and press the MLG door in place while that cures. I should be able to pop the door off after the FLOX cures and have a really nice seam.
