BEZJet Build
Date:  3-23-2013
Number of Hours:  1.00
Brief Description:  Mounting Pitch Tim Actuator
Installed 2 Click bond fasteners. I sanded and prepared the area. The Click bond fasteners had 2 small holes drilled in them and installed in a bed of flox. The Hole is to ensure FLOX flows through the click bond base into the 2 Plys of Bid to ensure the click bond does not rotate when installing the Locking nuts. I also used clear Box Tape on the back of the bracket to ensure it would not stick as the click bond fasteners cured.
Pitch Trim Actuator Temp Mounted in Place
Click Bond Fasteners In place Curing
