Brief Description: Right Winglet Trailing edge Spar
Completed the trailing edge spar layup for the Right Winglet. I laid 3 plys BID at 45 Deg and 2 plys BID at 45 deg over the hinge area. the hinge area layup extends the entire length of the Hinge line. I did this because I will bond a continuous Carbon Hinge on for the rudder. I then peel plyed the trough and hinge bonding area.
