BEZJet Build
BEZJet
Foamed in Transponder Antenna and Ground Plane
I used Poor Foam to cover Grounding Plane and Transponder Antenna. I left a hole to access and install the coax connector for the antenna.
Foamed in Floor
Foamed in Floor
BEZJet Home
1426
Aileron
Antenna
Brakes
Cockpit
Firewall
Flight Controls
Fuel Sump
Intake
MLG
Motor Mount
Nose
Nose Landing Gear
Speed Brake
Strakes
Winglet
