BEZJet Build
Date:  2-16-2013
Number of Hours:  3.00
Brief Description:  Installed Transponder Antenna
I removed foam in the rear cockpit down to the skin and Microed in the Transponder antenna and ground plan. The ground plan is 10" in Diameter and made of Aluminun. I used cleko's to hold it in place while the Micro cures and will cover it with Foam and BID.
Area prepaired for Ground Plane
Ground Plane and Antenna
Antenna and Ground Plane mirco'ed in place
