Brief Description: Installed Internal Rudder Return Spring
Fabricated Return Spring Tub and wooden plug. I then uesed piano wire to construct the return spring hooks for both ends. on the rudder end the hook was enbedded into Flox and on the tube end it was hooked through the wodden plug.
