BEZJet Build
Date:  11-4-2012
Number of Hours:  3.00
Brief Description:  Attached Left Winglet with Bondo
I measured the winglet per plans and marked out the area to cut out of the wing. I then cut out the section and blocked up the winglet checking the measurements like 15 times then used Bondo to secure the winglet in place. I then measured it again. All looks good. I will have to build a table to raise the wing high enough to turn it over and work on the Join area.
Left Winglet Bondowed in place
Left Wing cut out
Left Wing cut out
