BEZJet Build
BEZJet
Added Cowling Lip to firewall
I needed to add a lip to attach the Enging Cowling so I used blue foam carved to contour to support the lip while it cures. I laid peel ply on the bule foam then laid 2 ply of BID 4" wide over the foam and then peel plyed everythign.
Blue foam sanded to contour and peel Ply applied
2 Ply of BID and Peel Plyed
BEZJet Home
1426
Aileron
Antenna
Brakes
Cockpit
Firewall
Flight Controls
Fuel Sump
Intake
MLG
Motor Mount
Nose
Nose Landing Gear
Speed Brake
Strakes
Winglet
