BEZJet Build
BEZJet
Completed fuel sump top cover
I removed the wood screws that was holding the contour to the ribs post cure. I then used Micro to fill the holes and layed 2 plys of BID strips covering the holes the length of all 3 ribs. I then added peel plyed to everything
Fuel Sump Top Cover
Fuel Sump Top Cover
Fuel Sump Top Cover
BEZJet Home
1426
Aileron
Antenna
Brakes
Cockpit
Firewall
Flight Controls
Fuel Sump
Intake
MLG
Motor Mount
Nose
Nose Landing Gear
Speed Brake
Strakes
Winglet
