When I originally installed the Nose gear actuator hardware it slipped when I drilled one of the mounting holes and I had to drill another hole which was to close to the error hole. So, I purchased new mounting hardware and Removed Old Mounting hardware and Installed new mounting hardware and installed Nose gear actuator. It came out perfict this time... That was a $100 lesson learned. :-(
