BEZJet Build
BEZJet
Painted and Installed the Master Switch Relay
Painted Clickbond studs with Zilatone and Installed Master Switch Relay. Also, wired Relay to positice terminal block using 12 AGW wire
Master Switch Relay
Master Switch Relay Painted and Installed
BEZJet Home
1426
Aileron
Antenna
Brakes
Cockpit
Firewall
Flight Controls
Fuel Sump
Intake
MLG
Motor Mount
Nose
Nose Landing Gear
Speed Brake
Strakes
Winglet
