Brief Description: Installed Hydraulic pump bracing, Relays and Paint
Faricated Hadraulic pump braces and glassed them in Place. Also, Installed Click Bond studs to mount the Hyd Pump relays. Cleaned eb=verything up and painted the inside of the nose. Then re-installed the Brakes, Hyd Pump and Relays
