BEZJet Build
BEZJet
Installed Bearkut Nose
Chopped off the Original nose and Installed Bearkut nose. 2 plys of BID at butted areas inside and out overlapping 2" on either side and down Nose seam. I used Liquid foam to fair inside step prior to covering with 2 plys BID.
Nose Chopped off
Nose fitted to fuselage
Nose attached
BEZJet Home
1426
Aileron
Antenna
Brakes
Cockpit
Firewall
Flight Controls
Fuel Sump
Intake
MLG
Motor Mount
Nose
Nose Landing Gear
Speed Brake
Strakes
Winglet
