BEZJet Build
Date:  9-11-2011
Number of Hours:  8.00
Brief Description:  Completed Lower Rear Canopy Barrel Latch Assemboly
Constructed the rear canopy lower latch/barrel assemboly the same way as the front. Used Foam to construst a mold with the Barrel Assemboly installed in the Foam. I then Hot glued the mold in the proper loacation. I then layed 2 layers of BID around the Foam. Once the BID was cured I removed the Foam and re-installed the Barrell assemboly. I then filled the hollowed out barrel mold with Flox to the top of the Barrel Assemboly. Once the Flox was curred I Added Flox and contoured it to guide Locking Anchor into barrel Assemboly.
