Brief Description: Vaccume Bagging the Canopy Roll Over structure
Starting the Roll over structure. Using Canop as the Mold I layed up the 1st layup in the canopy after sanding the plexiglass where the Bows will be cut later... After it cured I removed the peel ply and layed up the foam rollover structure and bagged it into place using Micro and pearcing pin holes thoughout the foam to avoid any voids
