BEZJet Build
Date:  2-28-2010
Number of Hours:  10.00
Brief Description:  Installing Front Canopy Hinge
I used Bondo to affix the roll over structure temporaraly to the canopy then leveled the canopy and the hinge. I drilled 3 holes into the Canopy side of the hinge and monted the canopy side of the hinge into a bed of flox using 3 AN4 bolts as anchors. for the rollover side I used Phanolic laminate affixed to the Rollover structure with 2 plys of BID at 45 degrees and also used Flox in the corners... Applied Peel Ply all around
Leveling Canopy to Install Hinge
Hinge Installed on Canopy and Roll Over Structure
Hinge Installed and Drying
