Brief Description: Mock Up of Variable Thrust Controler and Throttle
Mock up from Sam Carter: For your consideration, in keeping the cockpit full width and not encoumbered with protrusions of the present throttle module, I will show one narrower being even with the outboard LH leg hole.(2.25 in.) The Thrust Vector enable/disable unit will be redisigned to fit where it was. I think you will like this. SAM
