BEZJet Build
BEZJet
Modification of Lower Motor Mount Hard Points
- Removed Foam from Lower Longerons and perpared area for Lower MM Hard point
- Jigged Lower MM Hard point in place and drilled and mounted Hardware
Jigging to Mount Lower MM Hard Point
Lower MM Hard Point in Place
BEZJet Home
1426
Aileron
Antenna
Brakes
Cockpit
Firewall
Flight Controls
Fuel Sump
Intake
MLG
Motor Mount
Nose
Nose Landing Gear
Speed Brake
Strakes
Winglet
