Brief Description: Modification of Upper Motor Mount Hard Points
- Developed new MM Hard Point on the outside of the longerons - removed skin and foam on front of C-Spar to create hardpoint - Floxed in Spruce wedge and glassed over using 4 plys of BID - Constructed and mounted new MM Hard points... Bolted through Spruce Modification and thru Existing Hardpoint extrusions
