I painted all of the carbon fiber Aerosport panel and console parts. In addition, I also painted the inside of the baggage door. I used PPG DCC color matched to the Aerosport interior panels. I sprayed with a flattening agent and used the Geoff Combs low pressure texture technique to create a simulated fine texture finish. The first image shows the planned aluminum insert color, which looks a lot lighter than it is.
