Brief Description: Wired control stick and audio jacks
This entry convers the last few days. We wired the audio jacks for the PMA8000 which will reside in the center console. I created a test panel to facilitate the checkout prior to installation. In addition, we wired terminal strips on both the left and right side of the fuse. There are 8 wires that run to the stick grip. They will be connected at this terminal strip. An 8 conductor wire passes across the fuselage to connect both stick grips in parallel. A separate ground was run to the co-pilot side which ties in with the co-pilot disconnect switch on the front panel.
