I have heat!!! This was not as easy as it looks. The baffle plans have the inlet on the back right baffle and that is where I installed in. Problem is, that is for vertical induction engines. Ihave a horizontal induction, fuel injected engine. I had to pull the baffle, blank off the port and gouge out another one on the right front inlet ramp. Not bad, just the usual two steps forward, one back routine. Net is still in the right direction.
