Brief Description: Fuel pump, brake lines and fuel lines
I replaced the aluminum brake and fuel lines with Bonaco lines. They look good. The fuel pump is installed, hopefully for the final time. I flushed the lines going to the fuel servo and then going to the spider. I am close to being able to fill the brake lines.
After much thought, I finally decided to go with an oil seperator. I didn't get a pic, but it has been mounted. It turns out, there is an accessory oil return on the right side of the engine, outboard of the prop governor. Excellent place for the seperator to drain.
