I had an extra hour this evening and really wanted to get everything set to fit the tanks. I bolted the Z brackets to the spar, while this should have been quick it took a while both because of the tight spaces and the search through the bags to find the washers.
Once I had all the parts it was straight forward. There were some Z brackets that fit tightly and I needed to find the right order to tighten down the three bolts.
