I noticed that I cannot make the lower right engine mount bracket fit properly. Upon investigation the slot that the mount fits into in the right bracket(F-801-E-R-1) is slightly too small to get the bracket and the spacer in there and line up the rivet holes. I need to open the slot in the F-801-E-R-1 so that I can swivel the enging mount bracket and line up the rivet holes.
The left engine mount bracket (WD-803-L-1-PC) was missing from my kit, but after a short call to Vans, it is on it's way.
Parts clecoed together, note bottom engine mount brackets are missing.
