Brief Description: Right fuel tank support bracket
I finished the right fuel tank support bracket, getting the leading edge contour right proved time consuming, as I used a series of files, but it looked o.k. in the end and fitted very nicely. I marked the 405's for the rivet holes and drilled two pilot holes through the brackets the ribs, and the 410 reinforcement plates that go inside the tank. I then drilled all holes to full size.
