Rogers Web Site
Date:  5-26-2014
Number of Hours:  3.50
Brief Description:  Fuel tanks
Today I finished riveting the tank mounts to the rear of the fuel tanks. I placed a dab of sealer on each of the pop rivets and also the working rivets. I then started to seal the tank edges, one of the lower edges can be seen, until I ran out of mixed sealer and lunch beckoned. After lunch I finished sealing the other tank. Now all I need to do is install the sender units in each tank and test for leaks. I'll do that later in the week after the sealer has cured properly..
Riveting the tank mounts to the rear of the fuel tanks
Sealing the lower edge rivets
Starboard tank finished sealing the rear edges
