Rogers Web Site
Date:  5-3-2014
Number of Hours:  3.00
Brief Description:  Aileron stops
Today, I riveted the aileron stops to both wings. I used an inclinometer taped to the side of the aileron with double sided tape, noted the reading, then moved the aileron 30 degrees upward. I used double sided tape on the stop itself so I could position stop in the correct position on the aileron bracket. I clamped the stop with a 'C' clamp and drilled the rivet holes. I then deburred the control stop rivet holes.
I removed the ailerons.
I drilled out the outer rivets that hold the outer aileron mounting together at the bearing end, as I had noticed, as many have, the worked end of the rivets are very close to the aileron mounting if the plans are followed exactly. I then countersunk the bracket on the inside and re riveted the bracket so the rivets are now flush with the bracket on it's inside and outside surfaces.
I replaced the ailerons, retorquing the pivot bolts.
I then removed the flaps, I had thought of using a single length of rod to hold each hinge together, but most on VAF's website suggest cutting it in half, and removing the centre 3 or 5 lugs from the hinge itself, and using two hinge pins for each flap, both being fed from the centre. This seemed the easier option so I'm going to do that.
Aileron stops riveted in place, one aileron refitted.
Port wing aileron stop
Port wing with double countersunk outer rivets.
