Rogers Web Site
Date: 4-16-2014
Number of Hours: 2.00
Brief Description: Starboard aileron
Today, I clecoed the rear skin and leading edge assembly to the spar and drilled the rivet holes to full size, #40 on the top edge and #30 the lower edge. I also drilled three of the trailing rivet holes, one on the upper side, two on the lower side of the rear skin, so I can use CS4-4 pop rivets there. I edged and deburred the starboard aileron spar, and the re-inforcing plates where the aileron hinges bolt to the spar.
I had a request that I could show a kind of plan showing the progress so far, and so that people can see which part of the plane I'm working on with reference to the rest of the plane. So I've put an image together and coloured it in. I hope it helps explain.
The red parts, the rudder, vertical fin, are done. As are the elevators and the horizontal stabalisers. Most of the work on the wings which are also red is moslty done. I am currently working on the ailerons which are in blue.
Working plan of the build so far.
