I had a second attempt at bending the trim tabs on the elevator skin, It started to go wrong yesterday as the wood block inside the skin moved more than it should. So I started again today and success, not the prettiest but definately servicable. I also riveted the spar together and re primed the damaged paint. I'll leave it to dry over night and get back onto it tomorrow
Left elevator tabs bent
Riveting the spar together
The spar after touching up the primer to repair it
