Back on my January 29th log, I was worried that I had not drilled the F-695 Gussets yet. I marked and drilled them per the plans and then read ahead in the construction manual. The gussets don't yet get drilled to the longerons and firewall angle. Build on.
The weather cooperated and I was able to prime the brake pedals. When dry, I sprayed them with Rustoleum Hammered Silver. I attached the master cylinders to the rudder bar. Tomorrow, I hope to finish mounting the pedals.
I began disassembling the fuselage assembly. I deburred, edge finished, and dimpled the forward bottom skin. I countersunk the floor stiffeners and the bottom of the firewall.
