Swinnys 4 Place Bush Explorer
BushCaddy L164
Fitting Flap & Aileron push rods and inspection ac
Made up the push rod ends and completed the inspection access panel frame work for the bell crank connection panels.
Made a mistake marking and forming the penetration through the bottom skin for the strut attach strap on the rear spar. Bugger !
Push rod end
Access panel framework
Oops...
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
