Swinnys 4 Place Bush Explorer
BushCaddy L164
Fitting Right wing Flap area fairings
Completed the fitting of the nut plates to the inspection access panel framework and then started the fitting of the reinforcing fairings to the flap & aileron openings areas of the right wing
Inspection panel framework complete
Fitting Right wing flap area fairing
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
