Swinnys 4 Place Bush Explorer
BushCaddy L164
Installing stringers to bottom of right wing.
Today I turned the right wing framework over and then riveted the bottom stringers to the ribs.
Typical vertical reinforcing angle at ribs beside fuel tank
Framework turned over
Fitting the stringer supports under fuel tank area
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
