Swinnys 4 Place Bush Explorer
BushCaddy L164
Assembling the spar reinforing plates , right wing
After predrilling and then priming the reinforcing plates for both spars, I then used solid rivets for the final assembly.
I made up the angle attachment brackets for the five wing ribs that had to be cut back due to the laminated plates inside the spars.
I then cut back the ends of the ribs that are positioned at these stations.
Much quicker doing this for this wing, unlike the first one!
Front spar
Rear Spar
Strut attahment strap backing plate
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
