Swinnys 4 Place Bush Explorer
BushCaddy L164
Leading edge ribs, left wing
Finished fitting the angles to the leading edge ribs after first replacing the top skin & tank and making sure all is aligned correctly.
The leading edge ribs are now securely held in place and I can now start fitting the leading edge skins.
Mounting plate for the Landing Lights
Angles running rib to rib
Top skin back on & Tank back into place.
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
